So as some of the 6.4 guys know, I'm starting a project soon to make a global explorer type vehicle at a fraction of the cost. Going to spend a year traveling around South America. Here's the build sheet so far, keep in mind there's TONS left to do, just trying to track down all the major parts right now!
Donor truck will be a M932A2 chassis and rolling gear
Going to mount a PLS HEMTT cab on the front bumper, for those of you who have no clue what that is, it'll look like this:
It will receive an HEMTT A4 style side radiator
Most likely going with a 450hp Cummins ISX motor with Eaton Fuller 10 speed, and a custom transfer case for the front axle
Air ride seats, brand undetermined, w/e is cheap, lol
2-5 gallon air tanks, one on each side above the fuel tanks
2-78gal MRAP self sealing fuel tanks and a midships style 100 gallon tank behind the engine bay for about 250 gallons of fuel
Fabricated water tanks, centerline between the frames, 200 gallons total
Twin air cleaners *dust during the dry season is horrible in South America*
Dual 40" mufflers
Complete waterproofing and fording kit installed *dif and trans vents in the cab roof* for a fording depth of 8'
Still haven't even started on the "rv" portion, as that will basically be the last part of the build, since getting powertrain and all the wiring to make it road worth will be a HUGE undertaking. For those of you who don't know, a 450hp ISX and 10 speed will require some pretty extensive fab work to make it work, but the end result will be a 70mph capable truck that gets 7mpg at around 30k lbs.
I know this has nothing to do with Ford, but I figured it was neat and a few of you might get a kick out of the extreme amount of overkill that is about to happen... Will update as I get parts but expect the build to start around the end of the year, as I still have to move to Phoenix end of summer, and so I don't want to start stock piling 5-ton truck parts just to move them...
Also the truck in the picture was built in Phx, so if he agrees to help me build mine, it shouldn't take us long once we've sourced the part, so hang in there!
Dual 40" mufflers
