OBS Disc Brake Swap Brackets From E-Series Van
Jakey
Ephrata PA 17522
Pair of E-series Van dual caliper disc brake brackets to convert OBS 10.25 to Disc Brakes and retain parking brake feature
I was going to do a rear disc brake conversion on my F250 but decided otherwise.
I'd recommend searching google for "Fordmann" to find a writeup that uses these components
In good condition, no surprises.
Pictures make the rust look worse than it is. Sandblasting or wire wheel would clean these up.
Includes everything pictured:
2 - Primary Brackets with mounting studs and locknuts
2 - Axle Flange 3.5" Diameter hole, weld material removed and tube pressed out
2 - Caliper Mounting brackets with associated bolts
Parking brake hardware, for looped end cable, as unassembled, shoes are shot.
$150 + $30 shipping
