Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
I was curious to hear more about this. I like my setup with the factory relay but would also like to have something that works more like a SD set up with the timer.
Tom
Tom
Exactly what it does. Runs the fuel pump for 20 seconds at power-up. When built into my harness, with the pressure switch, it will run the pump at key on and shut off if you don't start the truck. If you do start the truck, the pressure switch takes over and the controller shuts down at 20 seconds. Allows you to turn the key on and not have the pump run all the time.
Nice work! I am looking forward to some more details down the road. I went with an inertia switch rather then an oil pressure switch for a safety shut down on mine and some times it would be nice to not have the pump run with the key on engine off constantly.
