Whitefarmtractor
- Joined
- Jul 7, 2012
- Messages
- 29
- Reaction score
- 0
96 psd, fairly new injectors, d66, yadayada
Started with a white smoke cloud, and cam sensor code.
Replaced sensor and started, truck was burping white smoke, coughing through intake. Thought it was head gasket or hung injector. Wasn't using water, no bubbles. Found an injector copper washer melted, o ring burnt. Replaced all injector o rings, reinstalled.
Tried another new cam sensor. No change.
Installed headstuds while I was in there.
Buzz test reveals injectors 1 3 5 problems. Ford tech said the new gray cam sensor will cause it to throw those codes.
Crazy part: unplugging the harness to #1 #2 injectors makes the motor run smoother, more power.
Replaced idm, no change..
Injector eff'ed up internally? O and no, the injector wires/plug are not crossed
I'm stumped
I'm stumped
