94.5stroker
When I changed out my injectors a few months ago, I had to remove the vacuum reservoir from the heater box in order to get the 7 injector out/replaced. I was thinkin about just splitting the heater box, but I asked my boss what he thought(I was using the shop at work) and he said to just break the glue holding the reservoir off of the heater box then re glue it. Well long story short after redoing everything I believe I have a vacuum leak. It takes quite a while for the ac(when I was using it this summer) to move from the defrost down to the vents, and the BRAKE! light stays on for like 10-20 seconds now where it used to just stay on for a short bit(I'm guessing as a bulb test). So I originally just figured I would live with it for now, until I get the time to swap my half of the heater box out with one from a newer OBS, that has the reservoir bolted on. But then I saw a SD reservoir for sale on here and was thinking maybe I could just use it and bypass that crappy glue on(94) one all together. What do you think? Sorry it's so long.
Thanks in advance,
Nick
Thanks in advance,
Nick
