Odd idiling
DieselFreak92
Warrington, PA
Recently my truck has been idling weird. When I first start it everyday I let it warm up a bit then go on my way but until I drive it for a good bit there is an odd idle. Usually it idles at just over 500 rpms but it will fluctuate sporadically and the needle will jump maybe 50-75 rpms. But after I drive for a bit it seems to go away. This also doesnt happen on every cold start, only sometimes. There is no loss in power and after I drive it for a bit the idle is fine. What could it be?
Tom S
Clean is big time an issue on IPR's Look at the tiny parts.
I have seen some even better ones but that was what I could find quick.
Talyn
What color is your CPS?
Grey CPS can cause this idle issue.
I have it myself.
Talyn
not to many places to get a black CPS now. =)
Yeah, the smallest part of the truck is in that IPR and it will keep the whole truck from doing anything.
ActionRick
Michigan
Clean the FPR screen . it sounds like there is air in the system . The return screen is how the air is removed .
Its rare that cleaning the IPR will help . There is a very fine filter that protects it ( edge) .. Most times they are worn & need replacement ...
Also , try unplugging the ICP sensor , see if the idle evens out...
DcMoore
Amarillo, Tx
That is wrong.
