Offset wheels?
Rtclayton53
Hughesville, PA
Well I'm looking to get a set of 20x14 fuel mavericks with -76 offset on 35x12.50x20 toyo mts. I don't know what to expect whether it's going to stick a foot out of the fender or just a couple of inches. I'm looking for suggestions or pictures if anyone's running a similar setup on their truck.
Cloverleaffarm
ridge farm, il
14 and -76
Let's just say majority of your tire will be outside the fenders.
You asked for suggestions, but I've learned not to give my suggestions on topics like this. Because I don't follow this trend.
Good luck
Pigman
Katy, TX
I meant a 20x12 wheel
A 20x14 wheel would have a -76 offset but a 20x12 would be -44 not -76. Also, what year is your truck? 1999-2004 Super Duties have narrower axles so the tires don't stick out as far as they do on 05+ models. Here's a couple pictures from the rear of my truck. 2003 F350 with 20x12's and 35x12.50x20 Trail Grapplers. I mounted one of my assemblies on a friend's 08 F350 a few weeks ago and the difference was definitely noticeable. The tire stuck out much farther on his truck than it does on mine. They still stick out far enough on my truck though to cover it in mud and throw rocks and break my passenger side-view mirror.
Rtclayton53
Hughesville, PA
Yeah I got all mixed up when I posted this, but thanks for the info! My trucks a 99. I like the way your truck is but I only have 33 inch trail grapplers, do you need a lift to fit 35's or just a leveling kit?
Pigman
Katy, TX
With a 4" lift my 35's STILL rubbed. I had to trim the inner fenders and pull them back with zip ties. The friend I mentioned in my first post with the 08 F350 had a leveling kit with 35x12.50x20's on 20x10's and didn't rub but when we put one of my wheels on he did rub. For 20x12's it'll take more than a leveling kit for 35's at least.
Rtclayton53
Hughesville, PA
So then I have nothing to worry about with the 99, running 35's on 20x12s?
(Im not worried if it rubs on the inner fender alittle that's no big deal)
Extended Power
I run 325/60/18 x 10" rims...still a 33" tire.
Stock suspension, rubs on tight turns to the point of cutting through the fender wells.
Air bags filled to 45 psi, hardly any rub at all.
