oil filter relocation
ncollins64
winchester springs, tn
Does anybody have any evperience with oil filter relocation kits for the 6.4s. I know river city diesel has a kit and elite also has a kit i think. I wanna relocate mine and use a spin on filter, plus it makes for a cleaner engine. Any thoughts?
AllGo'N'Show
West Canada
Looks really good, subscribed for some reviews
Dzchey21
wyoming
The only one i have personal experience with is the elite set up on godzilla, only downfall i saw is its pretty messy to pull the engine because it basically drains the whole time, really not a big issue but thats the only thing i could maybe complain about. As always with external lines you run the risk of rubbing, heating ect where the hose might develop a leak and the bad part is you could pump all the oil out of the pan before you even knew you had an issue...
that being said even Cat uses external soft lines, seams to work just fine even in high abuse areas... only thing i think i would add is an external oil cooler to go with it.
AllGo'N'Show
West Canada
Looks like a great kit as well, read through the instructions and seems pretty straight forward, only thing I noticed was they use self-tapping screws into the CAC to mount the cooler, so aftermarket IC guys may need to come up with their own mounts or make sure the screws don't penetrate the core.
gman1
Michigan
I was thinking the same thing for those of us with after market coolers. Was thinking about calling them to see if they have anything in the works for after market CAC,s.
derrick36
I looked into it a while back using OEM stuff. No experience yet, but I can probably dig up part numbers if you're interested.
http://powerstrokearmy.com/forums/showthread.php?t=7854
derrick36
Was everything factory parts? I didnt know they offered oem kits
E-series vans have a remote mount filter. It looks like the only things you wouldnt be able to reuse would be the hard lines. No biggie though. Im dure some suitable hose could be sourced from summit or jegs pretty easily.
ncollins64
Ive been looking at the bullet proof kits alot here lately. I may go that route since it comes with a secondary oil cooler. Seems they have good products. Any thoughts before i pull the trigger?
Hammer Down
might be a dumb question but have you guys seen any issues with it taking longer to get oil pressure due to the remote mount?
powerlifter405
Butt Town
do you still have the parts list for the E-series relocation filter?
