JuststrokeIT
- Joined
- Oct 9, 2011
- Messages
- 369
- Reaction score
- 0
My buddys 08 with 6.0 manifolds has oil coming out of the base of the EBP tube. The truck has blowby but its always had quite a bit it and its a steady stream also its not under pressure really its no where near enough to even push the cap up so Im hoping its not a cracked piston. We were just in doing head studs and gaskets the same time I did mine and all the pistons looked good with no signs of cracks. so my question is if its not a piston could it be a bad turbo seal and if so how would I go about checking this
