e99coalbaron
I noticed a large puddle of oil underneath my truck today. Its coming from somewhere on the drivers side of the block. It may be the oil cooler, but i just replaced 1k miles ago. Any ideas or other suggestions?
Didn't check the valley, but oil filter is definitely tight. Its on the drivers side of the motor below the oil cooler, covering the motor mount, block, pan, and finally falling onto the front axle and then to the ground.
Valley is dry.. so that must mean oil cooler?
