Oil leak??
mattjpine
After noticing a few oil spots on the driveway, I climbed underneath and saw oil drops on each of the bolts that hold the oil pan up.
I reached around on top and didn't feel any puddles. Is there a gasket that could be leaking somewhere or another issue?
My09Ride
Central Pa.
Yeah, me too. To fix the bedplate, it is cab off, engine out, turned upside down, and replace some gaskets, and goo. I'm going to wait until something else goes bad or it is run out on the floor. What does the hierarchies think??? Just IMO????
DEEZUZ
NO PUKESTERS
NWI
How's your blowby?
Eh, doesn't matter anyway, they all have extreme blowby, causing these plates to leak.
6.4f350
Probably bedplate. I just sealed mine back up 7,500 miles ago when I did the motor, used grey RTV on the seals and everything. It still leaks. It isn't bad, just enough to constantly be wet around the pan. I never see any drips.
mattjpine
Not sure what the blow by is but it seems like the leak might be from the oil filter housing. One side is completely black. I sprayed some brake cleaner on there to see if it builds back up
