Oil Pan Repair
juniort444e
Slippery Rock, PA
I have been battling a pesky :cursing: oil leak for quite some time now. Tonight I decided I was going to drain the oil and figure something out, and that's when I noticed I had a fine crack in the bottom of the pan.
So what are my options? Can I jb weld it? Weld it with mig or tig with out catching the whole truck on fire? Or replace it?
I know this is stupid, but if I have to replace it, does the motor have to come out?
I also thought about cutting out a section, which would help me clean everything really well on the inside (not sure if it would be enough tho) and weld a new section back in. Sounds like a lot of work tho.
Just lost on this. Any help is appreciated.
DEEZUZ
NO PUKESTERS
NWI
Pull motor. New pan, comes with new dipstick seal and assembly also. Motorcraft only, do not go aftermarket
co04cobra
WV
If it's only cracked and not rusted it can be welded. Drain oil, brake clean around hole, air blow around the crack and inside, then weld.
We have fixed many oil pans this way with small holes or cracks. 7.3s, 6.0s, etc...
juniort444e
Slippery Rock, PA
Thanks guys. I was talking with my dad since he welds for a living and he will try to weld it for me.
And after hearing that that's what you do Cobra I will definitely give that a shot since I don't have much time for pulling the engine right now.
Do you mig or tig weld the pans? My dad only has mig welders available to him, but I have a few friends that can tig if need be.
co04cobra
WV
Mig is what we use, but I think tig could be even better since it would keep the heat down better.
You will fight a little oil seeping as the heat from the weld goes through. You may have to stop and reclean depending on how much comes out.
You can also jack the truck up on opposite side of the crack to help get some of the oil to run away.
With your dad being a welder he won't have any problem with it.
juniort444e
Slippery Rock, PA
All great tips that I didn't think of. Thanks a ton.
I will see if one of my buddies has a portable tig that they can come out here with, if not I will let my dad work his magic.
The truck is sitting with the oil drain plug out until it gets fixed, to help try to dry up some oil, but I will jack up the one side tomorrow to help even more.
Thanks again.
fastersteve
Don't use brake cleaner on parts you're going to weld. The combination of the Argon gas, arc of the welder and brake cleaner creates phosgene gas, which was used in chemical warfare in WW1. Tiny amounts can be fatal.
http://en.wikipedia.org/wiki/Phosgene
Acetone or mineral spirits are a much safer choice.
co04cobra
WV
This may be true but the compressed air finishes drying it before you weld. If that tiny of an amount is fatal, I couldn't count the # of dead mechanics I would know.
I'm not saying people shouldn't use caution, but I would be more worried of the truck falling and causing my death, before that combination first.
backwoodsboy
Merica
This is only true for chlorinated brake cleaner.
juniort444e
Slippery Rock, PA
Moroso makes a gasket you can use instead of the gray death. It is possible to replace the pan without pulling the motor.
Please elaborate more for me. This would be the first time I have ever heard of someone saying it is doable, and Im all ears.
The good part is that we are still alive and did not die from phosgene, but I couldn't get the last couple of drops out of the pan and it prevented any penetration of the weld. It doesn't help that my dads little mig welder is crap. So for now I put jb weld on it that is oil resistant.
Im thinking of cutting out the bottom so I can dry the inside out completely, and put a little thicker peace back on with the oil plug and dimple.
co04cobra
WV
It is not always easy to get it dry that is for sure. I have repaired a couple by cutting off the bottom, like you are describing, and then welding the piece back after repairing the hole.
It is more time consuming, but does allow to get everything much cleaner inside.
juniort444e
Slippery Rock, PA
Im pretty sure that when I get a weekend when I am not busy that, that is the way I am going to go. Plus when I put on that fancy billet dip stick piece, the old one stay in the inside of the oil pan, so itll be nice to get that out of there as well.
