Oil temp vs coolers
Twan
Berthoud, Co
After i did my injectors my oil temp likes to run warmer when pulling my 5th wheel, temps are great pulling my other trailers so fare. My stock oil cooler was replaced, hpop replaced when i did injectors. What is a safe oil temp to hold (for long times) and what is a safe temp for a mountain pass? I wish i would have had my insight when it was all stock to have stock numbers to go off of. What is a max water temp to hold for a mountain pass?
If my oil is getting to hot, would the oil cooler from Bullet Proof bring my temps done? I'm sure I need to upgrade coolers, because in the summer when my oil was at 214 water 210, pulling my inclosed trailer, out side temps at 90-100 running 80 mph my AC was not as cold, when oil was at 220 for hills it turned the ac off, cab gets hot fast.
Thanks guys.
Snake
Flo Rida
If you're running synthetic oil, 214* EOT's are nothing to worry about. Probably don't even need to worry about it if you're running conventional oil.
What is your ECT and EOT when you're not pulling a trailer?
Only other thing I can add is to slow down. 80 mph pulling a trailer is asking for a trailer tire to blow out. You'll also see your ECT and EOT come down.
Twan
Berthoud, Co
Pulling the 5th wheel temps stay around the 230* empty running to and from Texas I was at 185-190 water and 190-195 oil.
I'm running T-6 Rotella.
Twan
Berthoud, Co
The 5th wheel will be pulled in the sumer alot, which temps will range from 70-90, few times in the 100's. on a plus, i hold a lower water temp truned up than my duramx stock, lol.
Twan
Berthoud, Co
Oh, my temps are lower in the winter, last winter going to Texas empty i was running 165 water temp.
Im going to have the tuners turn my fans on at a lower temp.
