Oilcity franklin pa area need help asap!
yotaneck13
Throttle pedal quit working. Ran a ohm test with the modis and no signal at all. Anyone around this area have one i could try and buy if it works. I need the truck back asap please help. Text my cell 814 516 5176 thanks
Cullin
Sent from my DROIDX using Tapatalk 2
yotaneck13
Guess i should have stated the truck. Lol. 2000 f350 cclb drw 7.3 auto.
BigAlsPSD
Pea Ridge, Arkansas
I know this is the WTB section but, are you getting an IVS signal? You can pull the assembly as well as clean the switches with electronics cleaners to try to resolve. Also the TPS on a 2000 can be replaced by itself without the entire pedal assembly.
Part number for the the ford TPS by itself is F4SZ-9B989-AA - Potentiometer or DY-967 Dorman 699-200 Accelerator Pedal Position Switch.
Another thing to consider would be a possible OD cancel switch chaffing at the column, it can blow the fuse for the TPS.
If nothing else, this is just another bump!
yotaneck13
Its hit or miss someimes it works sometimes it wont not drivable. I had a cps code and a acell switch coxe too so im lost. Going to check the od switch tm b4 i bu a new acell switch
