Opions on next set of injectors
baderic03
warren ri
Should I go to a 350/200 or 450/200
Truck is staying on fuel only looking to make over 600rwhp on fuel only And the truck is driven and sled pulled nothing else
baderic03
warren ri
450/200 nate at unlimited diesel Up grade my turbo to what I have a s475 on the truck
mattman347
Readyville TN
Something in the 350/200 range would be the best "all around" injector. The 400% nozzle needs a lot of tuning attention specific with each truck.
baderic03
warren ri
truck aint getting a cooler its getting 3.5in pipen along the front and back up to the motor the truck dont tow it dont plow its gets daily driven and sled pulled. im not going to see a great enough gain from a cooler to justify spending the money on one.
the truck is going on the dyno today at the shop with the new s475 on it and my 250/200 so we will see what it does if its any were in the 550+ rwhp range the goal will be 700 on fuel and i wanna keep 200% nozzles to keep drivabilty and idle as nice as possible
baderic03
warren ri
truck is getting the trans built next week and then it will be ready to hit the track and sled pull competively
97BambiBasherPSD
Edinboro, PA
Well if your gonna competitively pull it then why not run the 400/400? I mean the tuning has come a long way and you know your gonna want some room to grow if needed. Might as well just buy them once and be done. There are a couple guys that daily drive with those injectors without any problems
Sent from my Pear phone using Tapatalk
I have over 600 with 300/200s with more left in it....go with them
Where and what kind of dyno are you guys getting.these numbers on? Bill at php eked out 560 on a set of 250/200s. Is a 200%nozzle draining the fuel to the point.that a 300cc inj is going to gain anything over a 250? Im not.being a dink just wondering.
My truck dynoed 405 with a 175/80s, 38r, a bosch high output fuel pump, and no wastegate/ebpv system. Ive since added new fuel lines(need to do rr and in tank mods/aeromotive fuel pump), and 100% nozzles, ditched.the 37x13.5 for a 35x12.5. The truck runs good(could.run better) and shifts great since I.dumped.the 37s. I would say 35s are the optimum size for my truck. 37s= huge drag. This is a bit.of.a.derail, sorry op, just wanted to.participate.
PSDEng
Bellefonte, PA
I got my numbers from Bean's dyno, I think it's a dynojet. I tapped out at 622rwhp and 1300ft/lbs. The truck had more in it, but it started to rain and we were tuning outside, so we had to get the dyno back into the trailer. It was disappointing because we finally started to make some progress with injection timing delay.
Ive heard beans dyno #s are a tad high. I dont have the experience.of.ever.having dynoed there but many have. That injector size is.potent either.way.
PSDEng
Bellefonte, PA
I don't have a reference point on another dyno so they very well may be high. But either way that's the number I give to people....
