OUO Blocks with Air Bags Pics
Swampfox
TN
Does anyone have pics showing airbags mounted to the tangs on the OUO traction block? Looking at the airlift 5000 air bags and guessing the bottom mount is removed and drilled directly on the bump stop on the block? Pics or more info is appreciated.
Layson
Give Dave a call at One Up Offroad. He should be able to help you out.
1 888 98 ONE UP
Layson
Check out the attached pictures.
WHY NOT
Carlyle IL
Ive put both firestone and airlift bags on top of OUO blocks and I will say the firestones are easier because of just one mounting hole on the bottom of the bag so you only have to drill one hole about in the center of the block. The air lifts you have to figure out were the offset holes will be then drill those. A daystar cradle would just be one mounting hole and allow more flex of the truck though.
geolp
MI
Attach bag to frame mount and make a template with the two holes for the bottom of the airlift bags. Transfer the template from bottom of bag to block when they make contact, then drill the tang with a right angle drill.
Swampfox
TN
1 888 98 ONE UP
Yea Dave is great to talk with. Was trying to get an idea of how it would work and was going to get the bags before calling Dave up. All the pics and replies help out a lot.
