Bustedknuckles
- Joined
- Aug 15, 2011
- Messages
- 1,503
- Reaction score
- 0
I am working on a 01 7.3 that sets a p2111 (ICP above/below desired) while towing. The backstory is the SES light would come on anytime you gave it throttle. Diagnosed that as 2 bad injectors where the armature plate was contacting the solenoid. Got those taken care of by the company that had rebuilt them about a year ago and i runs great but the SES light comes on after hammering on it while pulling a trailer. The truck is bone stock other than a CAI, it holds 55 psi of fuel pressure checking it right after the pump. The oil was just changed using a motorcraft filter and rotella 15-40. The icp sensor has a 5 volt refernce, good ground and the signal voltage looks good and agrees with signal voltage on the scanner while wiggling the wiring. ICP holds 2200 (lowest i saw was 1900) under WOT and the IPR doesn't' demand over 65% at WOT. ICP at idle is around 465 but jumps around, 9% IPR at idle. Im kinda leaning towards a sticking IPR but dont know how to verify that. It does have a little bit of a rough idle....
So anyway, i'm about out of ideas. Do any of you guys have any ideas? I have the tools and knowledge to check almost anything y'all need me to check . TIA
