overdrive light flashing of shifter
Mark Kovalsky
SE Florida, USA
The flashing light means a code was stored to tell you what's wrong. Without the code everybody is lost. The auto parts stores that read codes free cannot read this code.
purpleheart350
Rokwall, Tx
Same thing happened to me yesterday. It didnt want to shift from 2-3 until about 3200 rpms and when it did it slammed into 3rd
99powerstroke7.3
Good ole Plainfield Illinois
its a code says pressure sol open circuit.....i unplugged my trans command that was on the truck when i did the flexplate and converter, i didnt have a bypass plug but it seems like thats the issue so i called banks to order the bypass plug and wow they were not happy to hear i was taking there product off my truck
Mark Kovalsky
SE Florida, USA
Unhook your battery's turn on the lights, it'll stop the od light and hard shifting
Yes it will, until the next time the problem is found. That could be as soon as the key is turned on.
The RIGHT way to fix this is to read the codes and fix what's wrong.
See? Read the code, find the problem. Unhooking the batteries would clear the code, but only until the key was turned on again. Reading the codes isn't a punishment, it is the easiest way to find the problem.
i was waiting for your response on the battery deal.... figured thats what you would say!
for those of you that are new here, mark was in on just about everything, if not everything, that was done with the 4r100... he has prolly forgot more about it then most of us even come close to knowing...
Viking
Minnesota
I had that off and on for a week then my truck stopped moving......
Sucks cause i couldn't get my truck in to read the code due to work.
zilla68
Moore Oklahoma
if you had the banks trans command, and removed it, you have to reposition the pins in the harness on the trans, as 1 or 2 was either removed or repositioned.
I removed mine and had a similar issue, and you have to make sure the pins are seated in the clip very well.
the wiring schematic is listed on their site, or at least that is where I found it when I needed it.
