P0087 and P0088 = HPFP headed out??
LovinPSDs
Evansville, Indiana
Got a buddy with an 08, 150K miles throwing P0087 and P0088. Does indeed mean the HPFP is headed south? Should we try the sensor first?? Any other advice?
WoodBoy
Alabama
Doesnt early 08s have a problem with the HPFP harness shorting out under the valve cover? Not sure on what codes it may throw
Big Angry Hillbilly
Harness usually grounds out and blows a fuse in the BJB causing a crank and no start condition. Can also cause a lack or loss of power.
TSB 07-23-2.
P0088 was an ongoing issue with earlier trucks, the original fix was replacement of the HPFP. Now the repair is just a reflash. All they did was widen the failure parameter a little.
Make sure the truck is at the latest calibration level, and ensure proper base fuel pressure and delivery.
