p0128 and ...
RedRice589
Ocala, Florida
Getting a P0128 Coolant Thermostat (coolant temperature below thermostat regulating temperature)
P0529 fan speed sensor circuit intermittent.
Getting those codes any advice? Truck won't warm up i pulled the codes on the Black Maxx. I habe my cold coolant defuel set on 170 and it won't get above 165 ect.... help please. Do i need a new thermostat?
Dzchey21
wyoming
Prob needs thermostats and you need to.look.into.the fan code to make sure it's not running all.the time
RedRice589
Ocala, Florida
Ok its running like normal fan runs at idle but it doesn't come on excessively. Anybody know where the thermostat and how hard is it to replace?
RedRice589
Ocala, Florida
Anybody else.... i did some research it sounds like i'll be doing the egr delete on my new truck and the thermostats at the same time... any suggestions?
Heavyhaul
Wyoming
Plan on a full day if you have never done it before. Also pull the drivers side inner fender out. It will help.
Rivets are the new duct tape.
Dzchey21
wyoming
If you have the egr coolers in place it's going to be a biach. Plan on w constable amount of time to do it.
If you don't think the fan is running excessively then your probably fine. Im actually not sure if there is a sensor or something that feedback to the engine to tell it how fast the fan is spinning. Maybe that code comes if the engine temp isn't what desired should be.
RedRice589
Ocala, Florida
Thanks alot guys i'm jist zipping back and froth from work all week i'll do the egr delete and the tstats this coking saturday thanks alot guys!
Big Angry Hillbilly
There is a speed sensor in the fan that feeds back info to the PCM. That's what that code is. A lot of things can cause that code, but I wouldn't lose a whole lot of sleep over it unless it comes back.
Blow the connector out with compressed air and put a little dielectric grease in there and keep an eye on it.
If it still has warranty the thermostat and fan clutch should both be covered under power train.
RedRice589
Ocala, Florida
No warranyy but i'll clean it out and put diealectic grease in it i figured it was a chain of events sort of thing.
Thanks, Adam
gman1
Michigan
While you are that far into the motor I would do the upgraded upper and lower rad hoses to if you didnt all ready do it.
RedRice589
Ocala, Florida
Got the egr delete an the thermostats inn now i have a question? The purple wire that powers my blackmax ,which fuse panel runs that?. Truck runs fine but black max has no power.
RedRice589
Ocala, Florida
Idk how to tell if it is its the purple wire that H&S says to use. I checked it with a test litght and no powa.... i'll look more in depth tomorrow.
RedRice589
Ocala, Florida
Ok now i'm getting 2 mores codes P0480 fan 1 control circuit P0528 fan speed sensor circuit no signal i did some research. Looks to be fan clutch. Hasn't had cooling issues i just want to
