P02263
JuststrokeIT
Got a turo performance code its a hard set code I cleared the code and 30 sec after starting the truck again it came back on what should I been looking for? What reads the turbo
JuststrokeIT
What tube or how is everyone routing their EBP tube i got 6.0 manifolds and I just flipped my tube upside down and had to bend it some to get it so that it was out of the way of everything the best that I could but it is still sitting right under the battery/degas bottle so I can deinatly see it plugging up me bending it some or the sensor rubbing since I imagine once the engine torques up it may rub ill have to look and see. I know my SCT has always read my sensor wrong as its always reading in the 100+ range even at idle but the actual computer has always read correctly I found this out after I replaced the sensor about a year ago since i thought it was just a junk sensor.I do notice the truck does have a different sound now thou. but i guess I can imagine the EBP sensor is what runs the VGT. I just got brand new rudys custom up pipes so I think my bellows should be good but ill look into them anyway
Motostroker
I have 6.0 manis also. Ill shoot you a pic of my setup. It's a 6.0 tube with a 6.4 sensor. I actually think they are the same sensors between the 6.0 and 6.4. But I'll check
JuststrokeIT
I watched it the other day when I got the code and the actuator is moving back and forth so im assuming its working? any other way to make sure its moving enough?
JuststrokeIT
I recntly had the turbos off while doing head studs and the rod where the actuator connects to them on the turbos moved very freely no crunch or sticking. I have not done a duty cycle
Dzchey21
wyoming
I think the turbo and actuator are probably good. If something was wrong you would have a p2563 with it I think
JuststrokeIT
Anybody have the international part number for the back pressure sensor. I got the tube from ford but they didnt have the sensor in stock would like to try and switch them out and clean the mass air flow sensor since after someone stating that I remembered I just got a new air filter and possibly some of the filter oil could have got on it. I hope i dont have as many issues as your having im staring to worry I hope you get yours figured out man
