P0766 AND P2703
Mike@MPD
Pasadena,MD
Ok, so just this morning out of thin air my truck was acting like it had no first and was shifting all out of wack, retuned it and it was fine for about 10 miles and let it sit, took it for another test drive and got about a 1/4 mile, now has wrench on and P0766 and P2703 codes, can this be a bad tcm or is it definitely a bad solenoid
bigrpowr
<How I Fly
Administrator
if its tcm acting up, i have another one here if you need it.
Mike@MPD
Pasadena,MD
Well the solenoid fixed the one problem, now its getting a bad 3-5 shift flare, thanks mike, i have a spare tcm here, gonna try that now :cursing:
Mike@MPD
Pasadena,MD
So does anyone think this might be a random tcm gone bad or randomly my directs went out, this is fking annoying as hell
ingrahams
New Hampshire/Africa
did the solenoids end up fixing this or did you need a new tcm? Mine just started doing this when I put the dpf delete and innovative tunes on it.
-Stew
Mike@MPD
Pasadena,MD
The output shaft speed sensor somehow was loose. Plugged it back in and all was fine
Sent from my Droid Charge
