P1280
bakerc167
NY
CEL came on yesterday, just got a chance to read it tonight an came up with P1280 injection control pressure sensor circuit low. Does this mean my ICP is bad?
Justin@DP-Tuner
Check the electrical connector. If it is covered in oil, replace it.
It could also be a weak HPOP. Do you have a way to monitor ICP?
that or while its running just unplug it and if it doesnt change the motor at all then its bad...
isnt 1211 the code that means a weak hpop?
bakerc167
NY
after the truck warms up the light turns off. ill try an unplug it tonight an see what happens.
bakerc167
NY
when I first start it the light is on an the idle revs up a little then back down to normal
