P132b code
Dzchey21
wyoming
Its a code for the boost control circuit, most likely for the actuator on the vgt
have you cleared the code and it comes back?
Check for the actuator to move freely with the key off, do not attempt to hold it key on its stronger than your fingers are
monitor vgt duty cycle, should be 95% at idle and 7% at WOT and seam to move freely throughout the range and throttle positions.
report back what you find
Rmartin-97
Mcarthur ohio
I don't have a way to monitor duty cycle right now. But the arm don't move freely. So I unhooked the arm from turbo and the actuator moves good but the arm on the turbo won't move.
Dzchey21
wyoming
Try to free it up. You don't need a new turbo you can take it apart and inspect/clean it
Sent from my DROID BIONIC using Tapatalk 4 Beta
