P2138 and dead pedal
ingrahams
New Hampshire/Africa
Well I was coasting down a hill and my trucks throttle blipped for no reason, didn't think anything of it and continued coasting to the bottom of the hill. When I went to pull away the pedal was dead and the idle climbed to around 1300-1400rpm, it drops back down to normal when I apply the brakes and climbs right back up when I let off. Checked for codes on the cts and it has "P2138 throttle/pedal position sensor/switch D / E voltage correlation" figured it was the position sensor so I put a new one on and there is still no difference. When I clear it the throttle blips but the code remains, any thoughts? Thanks
-stew
