I usually just use primer, i always use an adheision promoter directly on the plastic to help it stick, bondo might be a bit over kill but it should stick.
That's what i like about a thin coat of bondo , it sets fast and you can sand no problem . It is a bit overkill but the more you do before you paint the better the finished product will be .
