Need to remove the passengers side head. #3 has low compression that I believe to be valve related. Anyone have any tips or tricks on how to remove it? Really dont want to pull the motor if I dont have to. Thanks!
You don't need to drop the motor mount or pull shroud to do it. All i did is tape the headbolts i couldnt remove up alittle bit and she was out in 5 minutes.
