I have a 03 f250 with a pcs controller. I've gotten it where I can drive it every day but it's far from 100%. Was wondering if anybody on here can help me with some tunes or know somebody? Thank you in advance
No there's a chart load vs line pressure. And on the tcc chart I've changed them in the tcu but it locks it up the same no matter what I set it to. And I'll upload some pics when I can
If you wanna buy a tune ********** sells them. I'll send you mine for free but I guarentee you it won't work Bc our inputs are different. I've asked for pictures or a tune. I can't help you without knowing anything.
Trying to figure out how to send pictures now new to this website. And I understand your trying to help me and I appreciate it. I can hook that input up that's not a problem if I have to
That inputs not a problem as long as the degrees it falls under doesn't keep the tc from operating correctly. For instance I simply changed that input showing 0 volts means 100 ect. I pulled my rpms off my cam instead of crank so where it asks for # of cylinders i put 1. I use calculated mph instead of pulling it off the rear end. You'd have to change my tune to make it work on yours. I can pm you my email and you can send your tune to me.
