Pics needed of an 05-07 6" lift 20x12, 22x12 or 22x14
Which set up should I go with?
  • Total voters
    20
HULK
Lake Forest, IL
I know there's a lot of wheel/tire threads, I have spent a lot of time searching on the Internet to get an idea what I want to run
Only problem is I'll find the look I want and can't find the specs on the truck
Here is the criteria for the pics I am requesting:
2005-07
Preferably Crew Cab short bed
6" lift
20x12 chrome or polished on 35x13.5 or 35x14.5 or 36x13.5
22x12 chrome or polished on a 36x13.5 or 37x13.5
22x14 chrome or polished on a 36x15.5 or 37
Much appreciated
HULK
Lake Forest, IL
I picked this truck up about 3 months ago.
30k miles
Need to change the wheel tire combo ASAP
Then I will be por15 the under carriage with a silver coat of the rust preventative under coat, then two coats of chassis black por15 top coat.
Next will be taking off the chrome tube steps replaced some AMP Power steps
"]http://
[/URL]
ProjecT 9
Houston
Just my opinion, but if you can go up 2 more inches I'd run 22x12 with 37x13.50x22's I think the look is perfect.
If you go into my albums I had a 06 harley at 6" with 22x12 and 35's. Also a 09 harley at 8" with 22x12 and 37x13.50's. Give you an idea.
ProjecT 9
Houston
probably not the best pictures of my 06 with 22x12's
06 with 22x10 BMF's and 35's
Just a reference 8" with 22x12's and 37x13.50's
HULK
Lake Forest, IL
Thanks for the help, you gave me a pretty good idea what I want to do. Looking to get a little bit better fuel economy and better acceleration so I will most likely end up going a 35x13.5 or 35x14.5 on a 22x12. So if I want to go to a 37 down the road I can with out having to go from a 20x12 to a 22x12 and buying another set of rims. I came across your truck a lot when I was searching I have to say you have great taste with trucks! :bowfast:
HULK
Lake Forest, IL
Don't have any pics, but man that Harley truck is sweet.
Thanks man, I have been looking for one for a couple years, but trying to find one with extremely low miles for the right price.
I have some big plans for this truck...appearance wise, as well as performance. If I could ever make my mind up on rim and tire set up. :fustrate:
