pics of 2wd with 22's?
JaxDiesel
I've got a 13 lariat 2wd. Looking to to run 22s and a street tire set up. Trying to find what width and offset won't stick out too bad
Kind
These are 24's but you get the idea. They are 10" wide and the offset is +11.
OBS73
I've been looking for someome running 24s and a 3/5 drop all over google. I want to step up from my 20s when I throw the I beams on. They look so small on superdutys.
BOHICA256
Midland, Texas
Thanks! I appreciate it.
I'm not sure how it would fit without the 2" leveling kit in the front. I'm wanting to see if it would fit with taking the leveling kit out, and take the rear block out, but I don't want to pay to get the leveling kit removed and then possibly put back in if it won't fit/requires ridiculous amounts of cutting.
It took some cutting of the fender liner and a little bit of the fog light brackets to fit these tires. It will rub at full lock in certain instances but it's not bad. Also at full lock there is not much room between the tire and the fog light bracket. I should do just a little bit more trimming on that, but I haven't.
And for alignment issues, I haven't had any. I definitely lost some ride quality with the 2" block but I'm okay with that to get rid of the 2wd front lean.
Here's mine.
22x10.5 -44 BMF's on Nitto 420's
Stock front height and lowered about 3" in the rear. It had two main leaves, an overload spring and a 1" block in the back. I'm down to just the two main leaves.
JaxDiesel
Anymore? Im still looking for ideas. want to run a 22x9.5/10 wondering if it will fill the wheel wells enough or if i need to do the djm drop.
