Pip Tunes - sensor question and egr question
brock1129
The truck is getting all the deletes done and I was just trying to get a definitive answer on which sensors to unplug. Egr and dpf.. The tunes are the new pip v.7 tunes. truck is a 2015
On the egr side - the two orange plugs and the black actuator on top of the erg?
On the dpf.. Everything gets unplugged including the egt sensors? And the nox sensor?
Now the nox sensor..is it located on the frame rail under the passenger door?
and lastly - can i leave the erg pipes in place using the stock egt sensor?.. my kit didnt come with the 1/8 to 1/4 adapter so i cant use my block of plates just yet..
Tia Brock
bigrpowr
<How I Fly
Administrator
You can use the blockoffs and I'm willing to bet your kit came with the adapter. If for some wild chance it's NOT there do the full install of the delete and plug the plate with an 1/8 bolt while I ship you the adapter.
brock1129
heavy - i left the sensors plugged in but disconnected the o2 sensors and left them on the dpf... is this correct? have about 20 miles on it so far and no mil light
bigrpowr
<How I Fly
Administrator
disconnect them all. they are not needed .
UNBROKEN
On the 2 NOX boxes, unplug not only the sensor but the wiring harness itself. They WILL short out and that circuit has NOX, MAF and glow plugs on it. Just remove the boxes all together.
brock1129
Unbroken/heavy - thanks for the input.. I'll go and unplug them soon as I can.. Unbroken I remember reading ur post but I couldn't find it.. Truck is freaking amazing now!
