Pmf 3-link question
nickg3130
West Long Branch, NJ
Hey guys I installed a pmf 3-link that I bought off of someone on here and I am having a slight rattle that seems like its coming from directly under my feet while driving. I used the factory hardware do I need to possibly upgrade it or go with a bigger sized nut and bolt? My kit came with no hardware. On the highway the truck rides fine it's just around town that I feel the vibration/rattle. I also may have to adjust the length maybe that's the problem. Maybe you guys can help me out. Thanks.
NotStock
Tucson, AZ
3/4" G8 hardware should be used with the kit. There is also a spacer that goes on the upper joint where it mounts into the factory radius arm mount. I would bet thats where your rattle is coming from. I can also give you the eye to eye lengths for the arms for your given lift height if you need. Shoot me a call if you would like, Im happy to assist in any way I can.
