PMF rsk install issue
97White'nSilver
Bozeman, MT
I'm in the process of installing a 3.5 rsk from PMF with x codes and have run in to a problem with the ubolt mounting plate/ lower shock bracket. It doesn't clear the dif on the drivers side at all. I'm going to cut the ear off the plate tomorrow but I wanted to see if anyone had run into this issue before and what they did to fix it.
MfRGbqb
97White'nSilver
Bozeman, MT
Thanks for the reply I never saw it mentioned in any of the install threads so I wanted to see if it was normal. Also were you able to use just a drop bracket for the track bar and did you need extended brake lines? Also did you keep your sway bar? Sorry for all the questions I haven't read of anyone doing the same combo and it wasn't my original plan so I'm flying blind so to speak.
I used the adjustable track bar from PMF, my truck already had extended brake lines from the ttb lift, and my truck does not have a sway bar so I cant help you there, should be easy enough to weld a longer piece between your sway bar links. No need to apologize man.
dsberman94
Pennsylvania
I believe I've seen on PMFs website that they sell an extended, greasable sway bar end link. I'm not sure if they're for OBS or SD or if they're the same between the two.
NotStock
Tucson, AZ
Our existing links will not work on the OBS. We have them on the list to design when we have some free time though.
97White'nSilver
Bozeman, MT
Got her squared away and I'm going to drive for a couple weeks and see if I need the sway bar and if I do I'll pick up some skyjacker links
