Power for mark/turn lights on mirror
psdguy95
Effingham, IL
Where can i tap into power for my marker and turn signal lights for 2008 and up mirrors on my 02? I'm assuming under the dash but not sure of what color wiring i need to look for. Thanks!
psdguy95
Effingham, IL
Brown is marker lights. Which can be found at the headlight switch.
Lt green is driver side turn signal and white is passenger side turn signal. That's what i found on the internet. I haven't gone out to the truck yet but i'm sure if you follow the wires from the turn signal switch they will be easy to find. Worst case i run wires up to the headlights and splice in for my turn signals there.
rascal
TX
Driver side is light green/white stripe and passenger side is white/light blue stripe. Wired in my 08+ mirrors on my 2000 last weekend. I spliced mine just behind the steering cloumn.
Works great!
rascal
TX
Do you have any pictures of where you spliced in at? Did you take the steering column apart to do it?
No, did not take any pics. I also did not need to take the steering column apart. I just found the wires in the harness that I accessed under the dash.
I was lucky and did not have to take apart the harness. The turn signal wires were clearly visible in the bundle of wires.
I also wired in the mirror heaters to be on when the key is on. I have seen some that use an on/off switch for that but I figured if they are always on from the factory that is what I would do as well.
Good luck.
