Power steering leak
stroker63
I have an issue with a power steering leak. It is leaking on the driver side of the truck behind a cooler. I cant quite tell if it is the vertical cooler with two lines coming out of the bottom, or if it is the power steering line that runs behind it. I also have a leak from the master cylinder. Has anyone had this issue? Are the hoses typical of a leak? Easy to replace? Or do I have a bad cooler that is spraying on the hose under pressure? It is red fluid so I know it is ATF.
