I can say that the pumps are hit and miss with these things. Some had issues with low pressure at idle from the first day off they bought it from the dealer. Others never had an issue. The fact is our pumps are weak and not a well put together unit IMO. Way to much variation in performance. When you consider these also work out brake system you would think they would have done a better job. A gear driven unit off the front cover would have worked like some of the older IH motors. Those things seem to never run out of flow or pressure.
