TANK'S 250
There are a couple of you that have changed your stereo's enough times, and have spent more money on all the changes, that you could have bought another truck...I need your input.
....here is where it gets tricky.
This is for my 2011 Road Glide Ultra CVO(sharknose)...
I'm keeping the stock Harmon Kardon head unit, I only want to change the (4) speakers and add a Amp....all for under $800.
Here is the other tricky part...Amp physical size has to remain small, and not draw to much power(bike charging system is 45amps).
Some other people have already installed RF PBR300.4 or Arc Audio 125.4 into their bikes(inside fairing) with awesome results.
This is what I'm looking at:
(4) Polk Audio MM6501UM 6.5", 40hz-25khz, 125watt component with built in X-over(saves space)...$220 x 2
(1) Rockford Fosgate PBR300.4, 75watts x 4...$170
Polk MM6501um stats:...click "tech specs" for more info
Polk Audio - Mobile Monitor Series - Mobile / Marine Speakers
RF PBR 300.4 stats:...click "specs" for more info
PUNCH Amplifiers - PBR300X4 - Rockford Fosgate®
...Keeping in mind... size limitations, current draw, and price range...do you think this is a good match(speaker/amp)?
