Question about a couple fitting sizes and types
KYkickinit
Henderson ky
I've gotten just about all the parts to do my fuel system from work and I think I'm gonna put it in this Saturday just got to get the last few parts. What size and style connectors do I need to attach to the heads? Also what do I use to attach my 3/8 hose to my stock fuel pump?
Lethalthreat7.3
Denver, CO
It depends on your exhaust clearance. I used two straight 1/8x6an for the front ports on the head. I used a 45*1/8x6an on the passenger side for my exhaust setup and a 90*1/8x6an to run under the turbo intake.
neverkickn
AR
I would use 45's coming out of the front ports and into your regulator. You can mount your regulator on top or the hpo reservoir to make that easy. I don't know how you would need to adapt to the back ports because I plumbed mine in through the fuel rail end plug.
A picture is worth more than an explanation here though. Let me see if I can snap one tomorrow of what I did.
superduty4x4
Newport, WA
Here is the easiest and cleanest way to connect to the stock pump.
http://www.strictlydiesel.com/p-2739-516-quick-disconnect-to-6-an-adapter-fitting.aspx
Your other options are using a compression fitting or simply clamping the hose to the pump. The ports in the heads are 1/8 npt. I would get some 6an adapters to plumb into the heads.
I hadn't seen that before... makes doing my e-fuel conversion on my OBS using and SD pump MUCH easier. Thanks for posting that!
KYkickinit
Henderson ky
Ok I was just asking because I don't think I could order one and have it here by Friday afternoon. So guess ill use a couple fuel injection hose clamps.
KYkickinit
Henderson ky
I've only had this truck for a little over a year so any help with the exact locations of the fuel ports would be really helpful. Thanks in advance.
