question???
bogey93
missouri
New to the site
I have several powerstroke fords from 02 7.3liter to 14 6.7liter. One in particular is a problem, (bought used )a stock 08 crew cab 4x4 with the 6.4liter now has 103xxx miles and dealer says needs new engine (says 2 cylinders are egged) a new ford motor is 16,000.00. was wondering if a 6.7 liter block can be swapped in for the 6.4 liter block? or if a 6.7 liter complete motor could be swapped in?
prior to engine failure we had a new radiator installed (prior to recall) found out ecm doesn't match vin, been in shop several times for ecu/pcm issues, couple injectors replaced, problem after problem. LEMON!!!
any and all help would be appreciated
Mark Kovalsky
SE Florida, USA
No, that isn't possible. They are two totally different engines. Not a single part will interchange.
Yes it could, because given enough time and money it could be done. I will bet that it would cost at least twice what a brand new 6.4L engine will cost you, probably like 4-5 times more. The things that have to change to make that work will boggle your mind.
You could probably find a remanufactured 6.4L for far less that $16k. You might have to take it to an independent shop, a Ford dealer may or may not want to install one for you.
