Questions I need help with please
chromehound
Hastings, NE
Ok I don't know if I'm just really bad at searching for stuff, if my brain is broken or what but I can't find some answers so I need some help please.
1. Anybody know where to get just the rubber for the drivers side tie rod? Mine got a hole and I put a unversial cut-to-fit on it because my local waste of property, useless dipchit Ford dealer says that they can't be replaced and that I need to buy the whole tie rod.
2. Can the 4" downpipe made by Powerstroker67 that Rudys sells be installed cab on? If I'm reading right it can (1 hour install time per Rudys site)
3. I'm planning to put a larger fuel tank on and from the looks of what I've found it seems the stock sending unit and such will still be accurate but I'd like a better answer than my gut feeling.
4. Do I need any special disconnect tools to remove the the fuel lines from the tank or for when I do the Airdog?
Thanks for any input, like I said I don't know if I brained my damage again or what's up but I haven't had any luck with my searches.
oneturboforme
1... Idk ebay maybe?
2..... If its a two peice and if you don't care about cutting your old peice then I think, I know I did it cab on with my afe and my mpd down pipes,
3.... Don't they usually come with all new sending units ect?
4...... You will need a fuel line disconnectkit... There cheap can buy them.at any auto parts store you will need a 1/2 and 3/8s
chromehound
Hastings, NE
I've been searching Amazon and eBay but so far no luck, I've got a few parts stores that can get specialty stuff that aren't open weekends to try yet.
It is two piece. I was more worried about the old one coming off and I have to cut mine since some a-hole welded everything after the dp together and forced it to fit the stock dp and since you should remove the cab to do almost anything on these I figured this was no exception and wasn't looking forward to that bill.
I looked at Titans site and they say you use the stock unit but I wasn't sure if it was like the OBS where you use the stock unit but make a new float arm.
