Radiator
kicker417
My radiator is leaking so I was wondering if anybody has write up on how to take it off or any other advice would help... And about how long would it take to pull it off
mortal798
Michigan
I have done mine about 3 times, it is pretty easy. You can have it done in about 3 hours if you have the right tools. Make sure you drain it first. Once the coolers are out of the way, you pull the core support and lift the radiator out of its mounts. When you put it back in, make sure it is seated in the mounts.
