Radio will not come on
Pwrcummins
Everything else works. Just not the radio. Swapped radios with a good one and didn't help and radio fuse is still good. Any ideas? I'm dying here with music.
Pwrcummins
Harness is good no pins bent. It randomly happened while in truck. It was working before then just stopped real weird
Pwrcummins
Checked volts and reading 12.
Idk what the issue could be
Pwrcummins
Checked ALL fuses and found 2 that where bad. Replaced them and now it works. Don't know how or why but it works now.
morepower02
MN
Strange. This past weekend my radio was blank then all of the sudden the time displayed. After about ten minutes the rest of the radio started working. Figure it is starting to crap out on me.
pistonbully
Fernie BC
There are actually 3 fuses linked together with a relay. They link your radio, power windows, and info center on ur dash cluster. Next time it happens check your windows and look for your info (How many miles to empty). If these are also not working then it is most likely your power supply to the relay. which is on the back of your instrument cluster.
