RCD 68 mm VGT
BlueWaffle
Grapevine, TX
I have an RCD 68 mm VGT with only 1000ish miles on it for sale. The turbo has been on my truck for about 3 months and has been a GREAT setup. The only reason I'm selling is because Matt and I are building something a little stronger next week :D Spools excellent on the street and still put down a 13.0 in my 8000 lb truck at the track (~580ish rwhp) The truck is just a toy that I usually just drive to the gym, home depot, etc so this turbo has not been beat on at all. Let me know if interested. $1850
BlueWaffle
Grapevine, TX
Do you think it's possible to get into the 700 range with that turbo or possibly that w a compound added on.
it might be possible with bigger injectors but I wouldnt do it. I've been told this turbo tops out with 205 for 225's. I think it would be hot and smokey and you still probably wouldn't get 700... on fuel at leasts. now if you wanted to spray it you can do it with 190s and this turbo easily. then again if you are going to be spraying it quite a bit I wouldn't go vgt anyways. there have been a couple people that tried vgt compounds before but it has. never worked out.
turbo sold pending payment
