RDS Stage 1 160/0 Premium build injectors
rusty1161
Whittier, CA
These 7.3 single shots have 20,000 miles of them, were checked by RDS and are in good shape and check out fine, flow a little low on the low side but up to spec on the high side, and new external orings installed. $800 shipped, no cores needed.
Rusty
Strokersace
Towanda, KS
Why selling? Can you describe the flow comments in a little more detail? Very interested.
Sent from my XT1080 using Tapatalk
rusty1161
Whittier, CA
I went to a larger set of injectors and a friend that was interested in these changed his mind.
The flow comments are what was reported to me from the inspection. I don't know of anymore detail, just that they are in good shape.
Rusty
Austin, Tx
If I had to take a wild guess, I would say that those comments would mean they flowed a touch low cc wise at lower ICP and lower PW and flowed right on the money at higher ICP and higher PW. I'm confident that if Jim really said they are good to go, then they are good to go.
posidon42
May be interested. Need to make sure this is the problem first and make sure I know what else I'll need to make this work.
Strokersace
Towanda, KS
Rusty, do you still have these? Have a friend interested. Took me a bit to get ahold of them.
