Reading ebp without an insight
loboost
I know the insight will read ebp through factory integration.
Does anyone know is the ts 5015 can be setup to do the same without adding a separate pressure sensor & mechanical gauge?
peixinho
Livewire TS 5015 does not read ebp correctly. I have verified this with other people that have the same unit... it reads between 50 and 200 psi which is not even close to right.
I have called and complained to SCT many times and they tried telling me that my unit was an isolated problem even though I had many other people verify the same thing. After this last phone call they informed me that the new update removes the ability to monitor the EBP sensor so instead of simply fixing their equation they deleted the ability.
Hope that helps
loboost
Hope that helps
Mine doesn't have the ability at all...its nowhere in the available pid's.
peixinho
Exactly... in the early versions it had it and it had the wrong equation so it calculated the psi wrong... with all the complaints they had they decided to delete it instead of fixing it.
Here is what it looked like (top left corner)
