Rear end chatter...
CSIPSD
Bend, OR
Long story...
Short version...
Does this sound like the factory limited slip going out?
When ever my wife turns, or accels hard you get a bad shutter, its been getting worse over the last few months.
Took the rear end apart and everything looks fine, but while its up on jack stands its extreamly hard to turn the wheels and will chatter like it does when your driving (altho much slower). Its the only thing I can come up with that would cause this issue.
When I changed the fluid about 3 years ago, I did not add the friction modifier. Forgot, or what ever... Could this cause the clutches to wear out quicker to where the steels are just locking up?
Damn thing feels like it has a locker in it around corners.
Arisley
Arlington, Texas
Could be. The friction modifier that was in the grease when you put it in may also be wearing out. Might try adding some friction modifier.
CSIPSD
Bend, OR
I did when I changed the fluid a few weeks ago. Didnt seem to help any.
Looking to see if anyone else has ideas as to a differant cause?
Any vendors sell a rebuild kit for the factory LS?
onebad7.3
MI
Sunrise ford seems to have good prices the last time I check. Too bad shipping would probably kill us or I'd send you my diff, just had it rebuilt 1,000 miles ago
kyle43335
Long story...
Short version...
are bolth wheels hard to turn in the same direction? or are they hard to turn one forward,the other backward(cycling the spiders)
if its the second one? it will be the friction material gone,and you only have the steels grinding off one another.
the first one would be something different,cause with bolth wheels spinning the same direction,your not cycling the spiders.
CSIPSD
Bend, OR
No, its when you try and move them in the other direction, or when you hold one and spin the other.
Dave
Add the friction modifier.
not having it in it ate up the LS
Charles
Truetrac...
They don't need pu$$y ass additives to get the jone done and do a hell of a lot better job anyway. And you can run synthetic fluid, or whatever else floats your boat.
BTW.... if you put synthetic in with the stock LSD on that oilchange, that may be your problem right there.
SICKS LITER
Salem, NH
if you are turning both the wheels in the same direction and theres binding, shuttering, or whatever than that is not a posi problem. it could be brakes, bearings, ring/pinion, pinion/driveshaft angle, u joints.
CSIPSD
Bend, OR
Truetrac...
I'd love to do that, and it might be cheaper parts wise, but from what I am being told I would have to completely reset the rear end. I am confident enough to remove the carrier and rebuild the factory LS, but not set up a gear set. If your telling me I could swap out the Factory LS for a truetrac and not rebuild or reset the rear end I would prefer to go that way.
I told ford to install a true trac in my rear end when it blew... thought they did until a few months ago when I noticed this scribbled on the invoice...
  • Rear end and trac-lock work.pdf
kyle43335
def clutches
Truetrac...
the factory 75/140 is synthetic
kyle43335
Home | Account | Contact ALLDATA | Log Out | Help
Select Vehicle | New TSBs | Technician's Reference
Component Search:
Conversion Calculator
2001 Ford Truck F 250 4WD Super Duty V8-7.3L DSL Turbo VIN F
Vehicle Level Transmission and Drivetrain Differential Assembly Specifications Fluid Type Specifications
Ford 10.50 Inch Ring Gear & Dana S135 - Rear Drive Axle
SAE 75W140 High Performance Rear Axle Lubricant F1TZ-19580-B
Specification WSL-M2C192-A
Additive Friction Modifier C8AZ-19B546-A
Specification EST-M2C118-A
Dana 80 - Rear Drive Axle
SAE 75W90 Thermally Stable Multi-Purpose Gear Lubricant XY-75W90-QL
Specification WSP-M2C201-A
Charles
You could leave the pinion alone and just swap everything over to the new carrier, but you would at minimum want to get the backlash right with a dial indicator. Which is super easy.
I would also get some new carrier bearings to avoid the bullsh*t involved with knifing the old ones off. You'll need a shop press to install the carrier bearings onto the carrier.
Although you could have that done by anyone, as you can do it before you even take the truck apart, and just have it done and ready.
It's up to you, but setting backlash and swapping carriers isn't really a big deal in terms of brain power. Just leave the pinion alone and assume the depth is good to go, which it will be, as you're not altering anything to change that.
SICKS LITER
Salem, NH
as charles said all you would have to do is set backlash, very very easy.
also check your side gears and pinion gears in the differential, broken or damaged teeth will cause issues as well.
Tom S
I am curious to know what is involved in setting just the backlash?
