rear springs
steele86
brush prairie wa
So after lifting my truck in February of this year the front end still sits about 1 1/2 higher then the rear l should I add bigger blocks or get new rear spring . I
HeavyAssault
Middle, VA
What year truck?? How big of a lift are you willing to go??
I'd add a taller block but that could lead to some drive line vibrations. I currently run a traction bar lift block from OUO. Sure it's an expensive setup but preventing vibrations was well worth the extra cost.
HeavyAssault
Middle, VA
I would need to see your rear spring/block setup to give a cheaper alternative. For me the OUO 7" rear traction block was perfect for my setup..
