powerstroker66
Put a 38 gallon rear tank in and when I turned the key on the gauge pinned beyond full. Newer sending unit in the truck and apparently worked from what the previous owner said. Any ideas?
That's what I said lol. You gotta have some power to the selector or it'll pin it at full...
Correct. When I pull my front tank for good, I'm going to complete the circuit with the wiring and eliminate the selector on the frame.
I'll be doing this also soon, any tips?
ok, thanks, I'm going with the 38 gallon rear tank, and my new 60 gallon in bed tank/box combo, and the strictly diesel obs set up.
Dang never thought about finding a filler plate to put over the switch since I only have my front Polly tank hooked up..
actually I thought about just using that switch to turn on and off the pump to transfer fuel if the front and rear switch will work like that.
