Recon tail moisture
nick0360
methuen ma
I got a brand new set of recon led tail lights and in getting condensation in them any way to prevent this the seller on eBay won't replace them so in stuck with $300 junk I wanna try to seal them up before the dioldes go out the only thing I can think of is the reverse bulb plug which is tight and I used factory gromet and the other thing it could be is the two rubber vent tubes anyone have suggestions
ftast350
Try drying them out (blowdryer) and as long as they can breath through the rubber hoses they should be ok.
f3502wd
Shouldve read my thread on here. The only thing that works is to make a BBB complaint on them
nick0360
methuen ma
Do you have a link on that thread? Cause I tried contacting seller and he lead me on for weeks by that time I was outta time for PayPal to help me and the seller was a dick so I got no options and recon said it was up to seller to replace the best recon offeres was a discount on a new set pshh all set
Tom@BigTimeKustomz
Bayville, NJ
Did you try putting a bead of silicone on the edge? That would be my first try. I had a set of cab lights on my dodge that leaked. Put silicone around the edge and the leak stopped. Best of luck man, I know how frustrating it is to spend hard earned money on things that don't work.
