Reduced engine power.
calawayfarmer
My dads 2015 6.7 gets a reduced engine power on the cluster screen under acceleration. Then the check engine light comes on, can't accelerate and speed limited. Notice in video I have the petal all the way down when the speed cutshttps://vimeo.com/127412233
DWhite
Oklahoma
From the video it looks like all the lights in the cluster is flashing like a voltage or wiring issue. Could be the video quality but it looks like they are flickering. But pulling some codes would help to pin point the issue much faster.
stevens6.7
Houston
Codes is the first thing I'd look into but I'm not sure it's the same on the 15s but how full is the DEF fluid? I only say that because if it's low on the 11-14s I hear it goes basically into limp mode under a certain miles to empty.
calawayfarmer
Shouldn't a 15 still be under warranty? Call Ford, tell them to come get it and call when it's done.
It is . it has 39,000 miles he has a 100k warrantee on it. He is going to call kelleher this week. It has all his tools for work, but they will bring him a loner.
